Thread: Power Window Help !!!
    5,822
    Arrow Power Window Help !!!
    2001 mustang GT: driver's side power window does not work. passenger side works from the driver's side switch and from the passenger side switch. power locks work and everything else works. when I push the button, you can hear an audible click, but no window movement.
    The same fuse runs "power windows / power locks" I took it out and put it back in and it was fine.
    What the heck is wrong?
    Any help is appreciated.
    edit: the window is DOWN right now if that makes any difference.
    Bridgeville
    1,278
    i had the same thing happen to me. and sometimes it would work an others it wouldnt until one day it stopped working an i took it to see what was wrong an the motor was bad, it was like 160 or something liek that for a new motor.
    motor sounds like its bad
    5,822
    well, believe it or not... and I seen this on another unnamed stang site... I already had the door panel off, so I took the palm of my hand and beat on the metal area in front of where the motor is located while holding the button down. It worked. I've put it up and completely down a dozen times now and it seems fine.
    Ninja
    Cranberry
    331
    mine currently has the same problem and i have yet to fix it
    1985 Mustang GT:Cobra r's.full exhaust.8.8 w/ 3.73's.forged 306 c.i..
    5,822
    mustangs are junk
    Senior Member no1fordgirl's Avatar
    Huntingdon, PA
    2,496
    Been there, Done that!!
    That happened to mine last year. Ford garage said its a common problem. You WILL need to replace the window motor. It may be a intermittent now, but it will eventually give out completely.
    United We 'Stang
    2002 Mineral Grey V6 5-spd
    Count Your Blessings, not your Problems
  1. help with power window harnesses
    By bigmack in forum General Tech
    Last Post: 07-25-2010, 06:21 PM
  2. 94-up power window motor
    By sinful rides in forum Ford Parts
    Last Post: 07-30-2009, 07:16 AM
  3. Power window problems
    By v6mustang01 in forum General Tech
    Last Post: 05-08-2009, 01:05 PM
  4. power window override????
    By 85stang in forum General Tech
    Last Post: 07-09-2008, 12:00 AM
  5. Power Window Wires???
    By 955.0 in forum General Tech
    Last Post: 04-03-2007, 02:43 PM
