Results 1 to 18 of 18
Thread: engine problems???
    In a Time Machine
    3,361
    engine problems???
    This happens from cold and rolling starts. When I put the pedal to the floor my engine misses. I thought it was water in the gas, but I put some dry gas, fuel injector cleaner, and octane booster/fuel cleaner in the past few times I've filled up.
    any suggestions????
    thanks in advance -Mike
    how built is your car?? i have seen alot of those have like a miss when the gas is slammed, i think if you bump the timing it will help..
    In a Time Machine
    3,361
    It's a stock engine with typical bolt on's and advanced timing
    Polar Vortex
    6,031
    Have you checked plugs, wires, ect?
    98stanggt 98stanggt's Avatar
    Dec 2007
    greensburg
    155
    hello
    haha im having the same problem....jus changed my wires and plugs and that seemed to have solved the problem......try changing the plugs
    In a Time Machine
    3,361
    they pretty new ford racing plugs and wires, msd distributer cap
    Dec 2007
    greensburg
    155
    hello
    hmm.... i was also told to check the pcv valve..... plugs and wires solved my problem my car was sputtering in every gear
    what gap are your plugs?
    Dec 2007
    greensburg
    155
    mine?
    mine?
    In a Time Machine
    3,361
    no idea
    94svtcobra.. Whats your timing at? you may be detonating... Also have you checked your harmonic balancer? I remember when my started to feel like that i went to put it in time and my balancer was out a lil bit and got a new one and it fixed everythign and ran like a champ.
    In a Time Machine
    3,361
    I'm not sure wat it's at the guy who owned the car before me installed the plugs and wires distributer cap, and also did the timing
    Do yourself a favor and before you buy another part for it, take the MAF off the car and CAREFULLY clean the MAF sample wires with a Q tip and either alcohol or carb cleaner. Be very gentle when doing this and don't break the wires. Do both sides of the wire (front and back). This will cure a MULTITUDE of problems associated with 94-95 cars. Do this and let me know if it fixes it, I bet it will help a LOT!
    In a Time Machine
    3,361
    thanks I'll try that
    In a Time Machine
    3,361
    I was thinking about somethin like that because it almost seems like its puttin to much gas into the engine
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    You should use non-chlorinated brake cleaner, it doesn't leave any residue behind like carb cleaner. Carb cleaner usually has some type of lubricant in it.
    All stock down to the tires
    355hp n/a
    520hp on nitrous
    In a Time Machine
    3,361
    what about rubbing alcohol
    Dec 2007
    greensburg
    155
    sup
    mine r 54 thous
  1. 04 mach 1 problems
    Last Post: 07-24-2012, 09:44 PM
  2. t5 problems???
    Last Post: 05-10-2011, 05:51 PM
  3. problems with idle
    By to50 in forum General Tech
    Last Post: 05-03-2010, 07:23 AM
  4. WTB: Engine Stand + Engine Hoist
    Last Post: 10-16-2008, 01:22 PM
  5. 5.0 engine shroud, battery tray, engine stand
    Last Post: 08-24-2008, 06:54 PM
