Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: What next
  1. #21
    an LSx?
    haha... good luck, but don't get too carried away, or you'll be broke and wish you had never done it!
    x2 on both of that...
    ls1 in a new edge mustang = pure love
  2. #22
    why are you on this board????LOL, and Scott.... do you have a bigger pic of your avitar??
  3. #23
    I like bacon! FineLineMtrSprt's Avatar
    Bunker Hill, Wv.
    672
    Long tube headers MIGHT get you 20hp..no where near 30-40hp on a Mod motor. And as it was said they dont have wires or dist. caps. I would do a larger upper plenum..C&L,BBK..the like. BBK has one now that has a Throttle body built into it. A Hardballer intake manifold...wont have the problems of the stock intake with nitrous puddling in it. Cam's..Hitec Stage 2's would be great along with upgraded springs and retainers. Then if you have the cash do a built bottom end...Cobra crank some quality rods and pistons.
    2012 Jeep Wrangler Unlimited Sahara hard top..frickin loaded!
    2010 Gt 5spd....WIFE's car.
  4. #24
    Senior Member TJH64's Avatar
    Delmont PA
    320
    I don't understand why the aftermarket hasn't embraced the mod motors ie heads, intakes. Parts are starting to trickle out, but the choices are minimal, especially for an engine that has been in the Mustang for 12 years
    Anyway, if you plan on making reliable power, plan on upgrading the reciprocating assembly, specifically the cracked powder rods, and the pistons. The usual bolt-ons would definately be a good start
    Fordstrokers 347 4.030 bore, 3.400 stroke, 5.315 rod, 10.6:1CR
    Canfield 195 heads, Ferrea 6000 valves, Comp springs, Ti retainers, roller rockers, hand bowl blended
    Camshaft Innovations custom billet core hydraulic roller camshaft
    TFS Track Heat, 75mm TB, 90mm MAF, 36lb/hr inj
    TREMEC 3550, billet flywheel, RAM clutch, 4.10 gears
  5. #25
    2.4 KB & Juice
    Export, PA
    844
    I've seen you drivin in Penn Hills on several occasions, car sounds great!!
    07 Silverado
    05 R6
    Sold: 03 Cobra, Built motor - 2.4 KB - N2O
  6. #26
    Ditch the n2o and put a turbo kit on that thing, then beat it till you break something, then upgrade.
  7. #27
    Bunker Hill, Wv.
    672
    Quote Originally Posted by TJH64 View Post
    Because its more expensive and time comsuming to make the OHC heads. Also its harder to improve on what can be had with decent port jobs for the money. Look at what cams are doing for the 3v motors..new article in MM&FF...51hp peak improvement..and up to 81hp under the peak!! Thats HUGE!!!
  8. #28
    96twinturbo bill412's Avatar
    May 2008
    penn hills pa
    187
    thanks guys.im going to get started ordering things and doing research.I plan on geting it supercharged over the winter
